Zum Hauptinhalt wechseln
HP Pavilion Notebook 15-ab293cl CPU Fan Replacement
Was du brauchst
  1. HP Pavilion Notebook 15-ab293cl CPU Fan Replacement, CPU Fan: Schritt 1, Bild 1 von 2 HP Pavilion Notebook 15-ab293cl CPU Fan Replacement, CPU Fan: Schritt 1, Bild 2 von 2
    • Start by flipping the laptop, revealing its back.
  2. HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: Schritt 2, Bild 1 von 3 HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: Schritt 2, Bild 2 von 3 HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: Schritt 2, Bild 3 von 3
    • Slide the tab marked with a lock/unlock symbol. The slide the other tab in order to release the battery.
  3. HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: Schritt 3, Bild 1 von 2 HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: Schritt 3, Bild 2 von 2
    • Once the battery is removed, unscrew and remove the both of the 7.5 mm screws off the black tabs using a PH1 screw driver. Then pry off the covers using the plastic opening tools.
  4. HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: Schritt 4, Bild 1 von 3 HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: Schritt 4, Bild 2 von 3 HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: Schritt 4, Bild 3 von 3
    • Remove all 16 size 3.5 mm screws with a PH1 screwdriver and pry the CD drive in order reveal one last screw that must be removed.
  5. HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: Schritt 5, Bild 1 von 1
    • Utilizing either a plastic or metal opening tool, begin prying the case from the laptop. Lastly, remove the remaining clips located on the back of the laptop.
  6. HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: Schritt 6, Bild 1 von 2 HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: Schritt 6, Bild 2 von 2
    • Once the laptop is fully open locate the cooling fan.
  7. HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: Schritt 7, Bild 1 von 3 HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: Schritt 7, Bild 2 von 3 HP Pavilion Notebook 15-ab293cl CPU Fan Replacement: Schritt 7, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Utilizing a PH00 Screwdriver remove the two 3.5 mm screws detaining the cooling fan. Then use tweezers to remove the plug connecting the cooling fan to the mother board. Lastly remove the cooling fan.
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
Gateway, Team S1-G2, Luster Fall 2018 Mitglied von Gateway, Team S1-G2, Luster Fall 2018
GCC-LUSTER-F18S1G2
4 Mitglieder
4 Anleitungen geschrieben
1 Kommentar zur Anleitung
very detailed. Thanks!
mrobinson29 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 29
Insgesamt: 1,332
