Zum Hauptinhalt wechseln
HP Pavilion Sleekbook 14-b013cl Battery Replacement
  1. HP Pavilion Sleekbook 14-b013cl Battery Replacement, Battery: Schritt 1, Bild 1 von 2 HP Pavilion Sleekbook 14-b013cl Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Flip the computer over and move the battery lock switch to the "unlocked" position (marked by an orange lock icon).
  2. HP Pavilion Sleekbook 14-b013cl Battery Replacement: Schritt 2, Bild 1 von 2 HP Pavilion Sleekbook 14-b013cl Battery Replacement: Schritt 2, Bild 2 von 2
    • Press the switch on the right-hand side of the back of the device towards the center until the gray battery icon is no longer visible. This will eject the battery.
  3. HP Pavilion Sleekbook 14-b013cl Battery Replacement: Schritt 3, Bild 1 von 2 HP Pavilion Sleekbook 14-b013cl Battery Replacement: Schritt 3, Bild 2 von 2
    • Carefully pull the battery away from the device.
Abschluss
Place your new battery into the slot you just removed the old battery out of, and follow the steps in reverse order to accomplish this.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 492
