Einleitung
This guide shows how to disassemble the HP Pavilion Sleekbook 14-b013cl in order to replace the cooling fan.
Was du brauchst
Flip the computer over and move the battery lock switch to the "unlocked" position (marked by an orange lock icon).
Press the switch on the right-hand side of the back of the device towards the center until the gray battery icon is no longer visible. This will eject the battery.
Using a Phillips #0 screwdriver, unscrew all nine of the screws from the bottom of the computer.
Using a plastic or metal spudger, carefully pry apart the palm rest from the rest of the laptop.
Disconnect the touch pad wire by flipping the black lever with a plastic spudger.
Unscrew the circuit board underneath the power button.
Remove this circuit board by pulling up and away on the plastic tab.
Using a Phillips #0 screwdriver, remove all the screws and take the metal plate off the mother board.
Remove the three screws holding the cooling fan in place using a Phillips #0 screwdriver.
Using a plastic opening tool, remove the power cable for the fan.
Remove the fan from the device.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
