Zum Hauptinhalt wechseln
HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement
Was du brauchst
  1. HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 2 HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement, Battery: Schritt 1, Bild 2 von 2
    • Flip the computer over and move the battery lock switch to the "unlocked" position (marked by an orange lock icon).
  2. HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: Schritt 2, Bild 1 von 2 HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Press the switch on the right-hand side of the back of the device towards the center until the gray battery icon is no longer visible. This will eject the battery.
  3. HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: Schritt 3, Bild 1 von 2 HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: Schritt 3, Bild 2 von 2
    • Carefully pull the battery away from the device.
  4. HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 1
    • Using a Phillips #0 screwdriver, unscrew all eight of the screws.
  5. HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: Schritt 5, Bild 1 von 3 HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: Schritt 5, Bild 2 von 3 HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: Schritt 5, Bild 3 von 3
    • Using a plastic opening tool, pry up on the upper edge of the keyboard.
    • There is a wire connecting the keyboard to the motherboard. Do not pull the keyboard away until you have disconnected it.
  6. HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: Schritt 6, Bild 1 von 3 HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: Schritt 6, Bild 2 von 3 HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: Schritt 6, Bild 3 von 3
    • To disconnect the wire, pry up on the latch holding it in its socket.
  7. HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: Schritt 7, Bild 1 von 3 HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: Schritt 7, Bild 2 von 3 HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: Schritt 7, Bild 3 von 3
    • Flip the laptop back over.
    • Using a plastic or metal spudger, carefully pry the top and bottom halves of the case appart.
    • Don't push the metal spudger in too far or you might damage the laptops internal components.
    • Do not pull the halves apart yet as there are still wires attaching them together.
  8. HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: Schritt 8, Bild 1 von 3 HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: Schritt 8, Bild 2 von 3 HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: Schritt 8, Bild 3 von 3
    • Disconnect the touch pad wire by flipping the small black lever using a plastic opening tool.
  9. HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: Schritt 9, Bild 1 von 2 HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: Schritt 9, Bild 2 von 2
    • Unscrew the small circuit board underneath the power button.
    • Remove the circuit board by pulling up and away on the plastic tab.
  10. HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: Schritt 10, Bild 1 von 1
    • Pull the top half of the plastic case off of the laptop.
  11. HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: Schritt 11, Bild 1 von 3 HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: Schritt 11, Bild 2 von 3 HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: Schritt 11, Bild 3 von 3
    • Remove all seven of the screws using a Phillips #0 screwdriver and pull the plate off the motherboard.
    • There is double sided tape holding the plate down, as well as the screws. Sufficient force will be required to remove the plate.
  12. HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: Schritt 12, Bild 1 von 2 HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: Schritt 12, Bild 2 von 2
    • Remove the USB wire which runs over the top of the hard drive.
    • The wire is stuck to the hard drive with double sided tape.
    • Remove the wire by carefully pulling towards the USB connector on the left hand side of the laptop.
  13. HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: Schritt 13, Bild 1 von 2 HP Pavilion Sleekbook 14-b013cl Hard Drive Replacement: Schritt 13, Bild 2 von 2
    • Remove the four screws securing the hard drive to the motherboard.
    • Disconnect the hard drive cable by gently pulling it away from the hard drive.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 15
Insgesamt: 2,042
