Einleitung
Since the operating system is stored in the hard drive, the laptop may not start or boot if the hard drive is faulty or not working. This guide will take you through the steps to remove the hard drive from your laptop in case the laptop will not boot or having problems loading to your desktop.
Ersatzteile
Keine Ersatzteile angegeben.
Slide the battery lock on the right side open.
Slide the Battery release latch on the left side.
Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
Using the spudger to lift up on the white tabs
Pull horizontally on the blue ribbon to disconnect the cables
Starting at a top corner, use the pry tool to split the case.
Slowly work around the case, pulling up gently to release the clips.
Remove the 4 x 5.5 mm screws connecting the hard drive tot he case.
