Einleitung
The keyboard is one of the main components needed to interact with your laptop. This guide will show you how to replace your keyboard if you are having issues with typing on your laptop or to remove the keyboard for any further repairs to your laptop.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Unplug laptop  from adapter and all other devices.
    • Unplug laptop from adapter and all other devices.
  2. Flip the laptop over with battery facing you.
    • Flip the laptop over with battery facing you.
    • Slide the battery lock on the right side open.
    • Slide the Battery release latch on the left side.
    • Pull battery out.
    • Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
    • Push screwdriver through screw hole top pop the keyboard.
    • Make sure the screen is open.
    • Pry up the keyboard.
    • The keyboard is still attached by it's ribbon.
    • Remove keyboard wire by popping latch under blue plastic
Abschluss
Sam Barkley
Mitglied seit 13.02.2018
959 Reputation
8 Anleitungen geschrieben
USF Tampa, Team S11-G2, Cheng Spring 2018 Mitglied von USF Tampa, Team S11-G2, Cheng Spring 2018
USFT-CHENG-S18S11G2
4 Mitglieder
10 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 45
