Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
The keyboard is one of the main components needed to interact with your laptop. This guide will show you how to replace your keyboard if you are having issues with typing on your laptop or to remove the keyboard for any further repairs to your laptop.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Unplug laptop  from adapter and all other devices.
    • Unplug laptop from adapter and all other devices.
  2. Flip the laptop over with battery facing you.
    • Flip the laptop over with battery facing you.
  3. Slide the battery lock on the right side open. Slide the Battery release latch on the left side.
    • Slide the battery lock on the right side open.
    • Slide the Battery release latch on the left side.
  4. Das Essential Electronics Toolkit
    Die wichtigsten Werkzeuge in unserem kompaktesten Kit.
    Jetzt kaufen
    Jetzt kaufen
  5. Pull battery out.
    • Pull battery out.
  6. Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
    • Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
  7. Push screwdriver through screw hole top  pop the keyboard.
    • Push screwdriver through screw hole top pop the keyboard.
    • Make sure the screen is open.
  8. Pry up the keyboard.
    • Pry up the keyboard.
    • The keyboard is still attached by it's ribbon.
  9. Remove keyboard  wire  by popping latch under blue  plastic
    • Remove keyboard wire by popping latch under blue plastic
Abschluss
Sam Barkley
983 Reputation
8 Anleitungen geschrieben
USF Tampa, Team S11-G2, Cheng Spring 2018 Mitglied von USF Tampa, Team S11-G2, Cheng Spring 2018
USFT-CHENG-S18S11G2
4 Mitglieder
10 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 5
Insgesamt: 142
