Einleitung
This guide will walk you through the step by step process to remove the mother board from your laptop. You will need to do this if you are having issues with the laptop booting or to remove the WiFi card or RAM.
Was du brauchst
Slide the battery lock on the right side open.
Slide the Battery release latch on the left side.
Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
Using the spudger to lift up on the white tabs
Pull horizontally on the blue ribbon to disconnect the cables
Starting at a top corner, use the pry tool to split the case.
Slowly work around the case, pulling up gently to release the clips.
Remove the 4 x 5.5 mm screws connecting the hard drive tot he case.
Remove the six 5.5mm Phillips #1 motherboard screws
Remove the one 3.5mm Phillips #1 screw from the WiFi chip
