Zum Hauptinhalt wechseln
HP Pavilion Sleekbook 15-b142dx Battery Replacement
  1. HP Pavilion Sleekbook 15-b142dx Battery Replacement, Battery Removal: Schritt 1, Bild 1 von 2 HP Pavilion Sleekbook 15-b142dx Battery Replacement, Battery Removal: Schritt 1, Bild 2 von 2
    • Flip the laptop over and locate the release switches located at the back corners of the laptop.
  2. HP Pavilion Sleekbook 15-b142dx Battery Replacement: Schritt 2, Bild 1 von 2 HP Pavilion Sleekbook 15-b142dx Battery Replacement: Schritt 2, Bild 2 von 2
    • Carefully slide the leftmost switch to the right, which is the unlock position, as shown by the orange unlock icon.
  3. HP Pavilion Sleekbook 15-b142dx Battery Replacement: Schritt 3, Bild 1 von 3 HP Pavilion Sleekbook 15-b142dx Battery Replacement: Schritt 3, Bild 2 von 3 HP Pavilion Sleekbook 15-b142dx Battery Replacement: Schritt 3, Bild 3 von 3
    • Slide the rightmost switch to the left, which will release the battery from the back of the laptop, enabling it to be pulled out.
    • Carefully pull the battery out away from the laptop, disconnecting it completely.
Abschluss
Now that you've successfully replaced the battery, restart your laptop and resume normal operation.
10 weitere Nutzer:innen haben diese Anleitung absolviert.
Jonathan
755 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 3-3, Hickman Winter 2015 Mitglied von USF Tampa, Team 3-3, Hickman Winter 2015
USFT-HICKMAN-W15S3G3
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 1
Letzten 7 Tage: 3
Letzten 30 Tage: 14
Insgesamt: 3,010
