Zum Hauptinhalt wechseln
Einleitung
By using the following tools and the following the steps below, you can simply remove your hard drive from your HP Pavilion Sleekbook and replace it with a new one.
Ersatzteile
Keine Ersatzteile angegeben.
  1. HP Pavilion Sleekbook 15-b142dx Hard Drive Replacement, Removing Keyboard: Schritt 1, Bild 1 von 3 HP Pavilion Sleekbook 15-b142dx Hard Drive Replacement, Removing Keyboard: Schritt 1, Bild 2 von 3 HP Pavilion Sleekbook 15-b142dx Hard Drive Replacement, Removing Keyboard: Schritt 1, Bild 3 von 3
    • Open the laptop and locate the keyboard. Identify the borders of the keyboard.
    • Taking plastic opening tools in hand, carefully and gently pry open the outer perimeter of the keyboard.
  2. HP Pavilion Sleekbook 15-b142dx Hard Drive Replacement, Replacing Keyboard: Schritt 2, Bild 1 von 1
    • Once part of the keyboard has popped up, continue to lift the keyboard until it is removed.
  3. HP Pavilion Sleekbook 15-b142dx Hard Drive Replacement, Hard Drive: Schritt 3, Bild 1 von 3 HP Pavilion Sleekbook 15-b142dx Hard Drive Replacement, Hard Drive: Schritt 3, Bild 2 von 3 HP Pavilion Sleekbook 15-b142dx Hard Drive Replacement, Hard Drive: Schritt 3, Bild 3 von 3
    • Pop out the black frame found underneath the keyboard using the plastic opening tools.
    • Once the frame is popped out continue to lift the frame gently.
  4. HP Pavilion Sleekbook 15-b142dx Hard Drive Replacement: Schritt 4, Bild 1 von 3 HP Pavilion Sleekbook 15-b142dx Hard Drive Replacement: Schritt 4, Bild 2 von 3 HP Pavilion Sleekbook 15-b142dx Hard Drive Replacement: Schritt 4, Bild 3 von 3
    • Locate and remove the silver hard drive cover in the bottom right corner.
  5. HP Pavilion Sleekbook 15-b142dx Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Detach and remove the hard drive from the black plug located to the right of the hard drive.
Abschluss
12 weitere Nutzer:innen haben diese Anleitung absolviert.
Rashed
670 Reputation
1 Anleitung geschrieben
USF Tampa, Team 3-3, Hickman Winter 2015 Mitglied von USF Tampa, Team 3-3, Hickman Winter 2015
USFT-HICKMAN-W15S3G3
4 Mitglieder
5 Anleitungen geschrieben
6 Kommentare
Fatto per il modello 15-b131el!!
Simone Milesi - Antwort
This technician has left out several crucial steps for this repair several screws on the bottom and several underneath the keyboard before the laptop casing will come apart, common sense for a tech but a how-to should not leave these details out.
dloeper2391 - Antwort
These instructions ruined my friends laptops. PLEASE do not post directions like this if you don’t know what you ‘re doing as folks like me will mistakenly assume that you do & attempt this and then damage cables. VERY, VERY careful folks! Cost me $200 for a replacement laptop.
Andre Bajew - Antwort
If you do not remove the screws you will crack the keyboard and cover.
HometownComputers - Antwort
WIll it support any SSD drive to upgrade from basic HDD?
Gajanan Thirumoolanathan - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 6
Letzten 30 Tage: 42
Insgesamt: 16,827
