Zum Hauptinhalt wechseln
HP Pavilion Touchsmart 10-e010nr Battery Replacement
  1. HP Pavilion Touchsmart 10-e010nr Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Power off device and place with battery facing up.
    • Ensure that your hands are not wet, even if the laptop is off or dead.
  2. HP Pavilion Touchsmart 10-e010nr Battery Replacement: Schritt 2, Bild 1 von 2 HP Pavilion Touchsmart 10-e010nr Battery Replacement: Schritt 2, Bild 2 von 2
    • Push slider on left-hand side of device into unlocked position. This slider is not spring loaded so it should stay in position afterwards.
  3. HP Pavilion Touchsmart 10-e010nr Battery Replacement: Schritt 3, Bild 1 von 2 HP Pavilion Touchsmart 10-e010nr Battery Replacement: Schritt 3, Bild 2 von 2
    • Push in right-hand slider with your thumb and simultaneously apply slight pressure away from your body.
    • It may be helpful to keep your left thumb on the left slider and push with both thumbs.
  4. HP Pavilion Touchsmart 10-e010nr Battery Replacement: Schritt 4, Bild 1 von 2 HP Pavilion Touchsmart 10-e010nr Battery Replacement: Schritt 4, Bild 2 von 2
    • Battery should easily separate from main device.
Abschluss
Sean
159 Reputation
1 Anleitung geschrieben
Washington State, Team S1-G5, Hope Fall 2018 Mitglied von Washington State, Team S1-G5, Hope Fall 2018
WSU-HOPE-F18S1G5
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 4
Letzte 30 Tage: 10
Insgesamt: 468
