Zum Hauptinhalt wechseln
HP Pavilion Touchsmart 11z-e000 Fan Replacement
Was du brauchst
  1. HP Pavilion Touchsmart 11z-e000 Fan Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove battery by pushing the two tabs and pulling the battery outwards slowly but firmly.
  2. HP Pavilion Touchsmart 11z-e000 Fan Replacement, Fan: Schritt 2, Bild 1 von 1
    • Slide a spudger under the outer plastic cover of the laptop.
    • Pry the outer plastic cover off of the laptop, one side at a time.
    • Prying the outer plastic cover off may take a significant amount of force.
  3. HP Pavilion Touchsmart 11z-e000 Fan Replacement: Schritt 3, Bild 1 von 1
    • Unscrew all screws attaching the fan to the metal backboard.
  4. HP Pavilion Touchsmart 11z-e000 Fan Replacement: Schritt 4, Bild 1 von 1
    • Turn the laptop over.
    • Slide a spudger in between the outer plastic cover of the keyboard and the main body of the laptop.
    • Pry the top plastic cover off of the laptop.
    • Prying the outer plastic cover off may take a significant amount of force. Be careful!
  5. HP Pavilion Touchsmart 11z-e000 Fan Replacement: Schritt 5, Bild 1 von 1
    • Unscrew the two screws that keep the fan in place.
  6. HP Pavilion Touchsmart 11z-e000 Fan Replacement: Schritt 6, Bild 1 von 1
    • Unplug the fan from the circuit board as shown
    • Carefully peel the tape connecting the fan and pull out the fan from the laptop.
Abschluss
Nguyen
295 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 21-22, Maness Winter 2015 Mitglied von Cal Poly, Team 21-22, Maness Winter 2015
CPSU-MANESS-W15S21G22
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 18
Insgesamt: 1,071
