Zum Hauptinhalt wechseln
HP Pavilion Wave 600-a010 RAM-Motherboard Replacement
Was du brauchst
  1. HP Pavilion Wave 600-a010 RAM-Motherboard Replacement, Hard Drive: Schritt 1, Bild 1 von 1
    • Remove the three rubber footings by prying from the bottom cover using the plastic opening tool.
  2. HP Pavilion Wave 600-a010 RAM-Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the three 24 mm screws from the bottom cover using a Phillips #2 screwdriver.
  3. HP Pavilion Wave 600-a010 RAM-Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Remove the bottom cover by lifting it up from chassis.
  4. HP Pavilion Wave 600-a010 RAM-Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Remove the three wires connecting the outer cover and front I/O port to the internal components (front usb and auxiliary assembly).
  5. HP Pavilion Wave 600-a010 RAM-Motherboard Replacement: Schritt 5, Bild 1 von 2 HP Pavilion Wave 600-a010 RAM-Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Remove the outer cover by gently pulling apart and pulling away from the chassis.
  6. HP Pavilion Wave 600-a010 RAM-Motherboard Replacement: Schritt 6, Bild 1 von 2 HP Pavilion Wave 600-a010 RAM-Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Remove rear I/O bezel using plastic opening tool to pry apart the four clips holding the I/O bezel to the chassis.
    • Remove all other remaining cables from unit using the plastic opening tool to carefully pry apart the connections.
  7. HP Pavilion Wave 600-a010 RAM-Motherboard Replacement: Schritt 8, Bild 1 von 2 HP Pavilion Wave 600-a010 RAM-Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Remove the HDD by first using the Phillips #2 screwdriver to remove the four 23 mm screws holding together the assembly and then pulling the HDD out of the chassis.
  8. HP Pavilion Wave 600-a010 RAM-Motherboard Replacement, Microphone: Schritt 9, Bild 1 von 1
    • Remove the three 24 mm screws that connect the top cover to the chasis inside the HDD compartment using theTorx #15 screwdriver (an extension and torque lever might be useful).
  9. HP Pavilion Wave 600-a010 RAM-Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Disconnect the microphone computer chip from the internal components by first peeling away the black adhesive holding the wires to the chassis and gently pulling the chip and wires from its connection.
  10. HP Pavilion Wave 600-a010 RAM-Motherboard Replacement: Schritt 11, Bild 1 von 2 HP Pavilion Wave 600-a010 RAM-Motherboard Replacement: Schritt 11, Bild 2 von 2
    • Remove the top bezel from the unit using a Torx Head #15 screwdriver to remove three 24 mm screws and a Phillips Head #00 screwdriver to remove the single 24 mm screw around the outside edge of the chassis.
  11. HP Pavilion Wave 600-a010 RAM-Motherboard Replacement, Speaker: Schritt 12, Bild 1 von 2 HP Pavilion Wave 600-a010 RAM-Motherboard Replacement, Speaker: Schritt 12, Bild 2 von 2
    • Remove the top chassis cover from the main chassis using the Torx Head #15 screwdriver to remove the nine 24 mm screws and then use the metal prying tool to pry the top chassis cover from the clips holding it to the main chassis and lift carefully away from internal components.
  12. HP Pavilion Wave 600-a010 RAM-Motherboard Replacement: Schritt 13, Bild 1 von 3 HP Pavilion Wave 600-a010 RAM-Motherboard Replacement: Schritt 13, Bild 2 von 3 HP Pavilion Wave 600-a010 RAM-Motherboard Replacement: Schritt 13, Bild 3 von 3
    • Remove the speaker by removing three 24 mm screws using the Torx Head #15 screwdriver and carefully lifting up and out from internal components.
  13. HP Pavilion Wave 600-a010 RAM-Motherboard Replacement, Fan: Schritt 14, Bild 1 von 2 HP Pavilion Wave 600-a010 RAM-Motherboard Replacement, Fan: Schritt 14, Bild 2 von 2
    • Remove the memory cover by removing the single 24 mm screw holding it to the main chassis using the Torx Head #15 screwdriver and sliding it up and out of its locking clips.
  14. HP Pavilion Wave 600-a010 RAM-Motherboard Replacement: Schritt 15, Bild 1 von 1
    • Remove the memory circuit board by pushing down on the white tabs on either side of the memory circuit board until it slightly pops up.
  15. HP Pavilion Wave 600-a010 RAM-Motherboard Replacement: Schritt 16, Bild 1 von 1
    • Lift the memory circuit board up and out of its connection, and out of the main chassis.
  16. HP Pavilion Wave 600-a010 RAM-Motherboard Replacement: Schritt 17, Bild 1 von 1
    • Remove the fan by removing the three 23 mm silver screws that hold the fan to the chassis using a Phillips Head #0 screwdriver.
  17. HP Pavilion Wave 600-a010 RAM-Motherboard Replacement: Schritt 18, Bild 1 von 1
    • Remove the fan from the chassis by sliding it up and out of the the clips holding the fan to the chassis.
  18. HP Pavilion Wave 600-a010 RAM-Motherboard Replacement, RAM-Motherboard: Schritt 19, Bild 1 von 1
    • Remove the heatsink from the chassis by using the Philips Head #2 screwdriver to remove two 24 mm screws.
  19. HP Pavilion Wave 600-a010 RAM-Motherboard Replacement: Schritt 20, Bild 1 von 2 HP Pavilion Wave 600-a010 RAM-Motherboard Replacement: Schritt 20, Bild 2 von 2
    • Remove two sides of the chassis from the motherboard and heatsink by removing one 24 mm screw using the Phillips Head #2 screwdriver and three 24 mm screws using the Torx Head #15 screwdriver and gently lifting away from the motherboard.
  20. HP Pavilion Wave 600-a010 RAM-Motherboard Replacement: Schritt 21, Bild 1 von 2 HP Pavilion Wave 600-a010 RAM-Motherboard Replacement: Schritt 21, Bild 2 von 2
    • Remove the heatsink from the motherboard by removing three 24 mm screws using the Torx Head #15 screwdriver and gently lifting away from the motherboard.
  21. HP Pavilion Wave 600-a010 RAM-Motherboard Replacement: Schritt 22, Bild 1 von 2 HP Pavilion Wave 600-a010 RAM-Motherboard Replacement: Schritt 22, Bild 2 von 2
    • Remove the motherboard from the chassis by removing four 24 mm screws (two on front and two on back) using the Torx Head #15 screwdriver and gently lifting out and away from metal chassis.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
clayton stokes
652 Reputation
5 Anleitungen geschrieben
2 Kommentare
Perfect unmount description, exept one point no. Sep 9 .. two screws are below the dard drive cover, one need a longer screwdriver shaft to open.
Where can I buye a mainboard replacement, I assume the exiting display controller is defect.
Thanks for your support.
Martin
Pauli.At.Mb@gmail.com
Martin Baur - Antwort
Step 6 what is the wire on top for
Anthony Witherspoon - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 19
Insgesamt: 2,772
