Einleitung
This guide will walk you through how to replace the front IO Board for the HP Pavilion Wave 600. A pry tool and a Philips screwdriver will be needed to replace this part. Ensure that the device is disconnected from the power source and all other devices are disconnected from the computer.
Was du brauchst
Turn over the computer and remove the rubber feet.
Remove the 8mm Philips screws indicated in red circles with a Philips #0 screwdriver.
Use a pry tool and lift the lid.
