Zum Hauptinhalt wechseln
HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement
Was du brauchst
  1. HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement, Front IO Board: Schritt 1, Bild 1 von 2 HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement, Front IO Board: Schritt 1, Bild 2 von 2
    • Turn over the computer and remove the rubber feet.
    • Remove the 8mm Philips screws indicated in red circles with a Philips #0 screwdriver.
    • Use a pry tool and lift the lid.
  2. HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement: Schritt 2, Bild 1 von 2 HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Pry open the casing from the back of the IO panel, as shown in the pictures.
  3. HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement: Schritt 3, Bild 1 von 2 HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement: Schritt 3, Bild 2 von 2
    • Finally, remove the two cables circled in red from the front IO panel.
  4. HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement, Mouse and Keyboard adapter: Schritt 4, Bild 1 von 1
    • Locate a blue USB adapter on the left side of the hard disk compartment.
  5. HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement: Schritt 5, Bild 1 von 2 HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement: Schritt 5, Bild 2 von 2
    • Take off the USB with gentle but firm pressure.
    • This is a single USB adapter for both mouse and keyboard, so you must get a wireless mouse and keyboard pair, or you will have to use the extra USB for the other one.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Kyaw Soe
321 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S8-G4, Banghart Fall 2017 Mitglied von Cal Poly, Team S8-G4, Banghart Fall 2017
CPSU-BANGHART-F17S8G4
4 Mitglieder
5 Anleitungen geschrieben
3 Kommentare
Seems like there might be enough room for a usb 2 port hub/splitter (such as Onvian USB Splitter Cable Male to 2 Female Adapter USB) to add an additional usb dongle (such an RF or Insteon USB)? Can you confirm how much room there are?
thomastranrx - Antwort
Since it's a year old project, I forgot most of the dimensions, but from my memory, it would be possible since it's located in a little groove that can probably fit a wire or two. (You can see it in step one picture)
Kyaw Soe - Antwort
Can i purchase this dongle anywhere? Is there any documentation on how to pair?
will - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 25
Insgesamt: 2,317
