Einleitung
If your computer has errors or just needs a speed boost, consider changing the RAM by following this guide.
Was du brauchst
Turn over computer and remove the rubber feet.
Remove the three 8mm Philips screws with a Philips #0 screwdriver.
Use a pry tool and lift up on the lid.
Remove the 2 black philips screws on the outside of the PC, to the left of the fan.
Put your thumb on the penny-sized hole, and slide the panel upwards.
Remove the panel to reveal the stock blue RAM.
You can now easily pull the RAM out of the socket, and replace up to two new ones!
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Hello srs, i follow the link to the Amazon Ram, and it is So-DIMM, but we need UDIMM for this Wave, it is correct? Wich can we use? Thank you so much, and best regards.
