Zum Hauptinhalt wechseln
HP Pavilion dm4-1265dx Clock Battery Replacement
Was du brauchst
  1. HP Pavilion dm4-1265dx Clock Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the laptop over so the bottom is facing up.
  2. HP Pavilion dm4-1265dx Clock Battery Replacement: Schritt 2, Bild 1 von 3 HP Pavilion dm4-1265dx Clock Battery Replacement: Schritt 2, Bild 2 von 3 HP Pavilion dm4-1265dx Clock Battery Replacement: Schritt 2, Bild 3 von 3
    • Push the sliding lock to release the battery.
    • Remove the battery by lifting it away from the device.
  3. HP Pavilion dm4-1265dx Clock Battery Replacement, Back Panel: Schritt 3, Bild 1 von 2 HP Pavilion dm4-1265dx Clock Battery Replacement, Back Panel: Schritt 3, Bild 2 von 2
    • Orient the device so that the empty battery port is closest to you.
    • Loosen the two captive screws holding the back panel in place using a Phillips #0 screwdriver.
  4. HP Pavilion dm4-1265dx Clock Battery Replacement: Schritt 4, Bild 1 von 3 HP Pavilion dm4-1265dx Clock Battery Replacement: Schritt 4, Bild 2 von 3 HP Pavilion dm4-1265dx Clock Battery Replacement: Schritt 4, Bild 3 von 3
    • Pull back and lift the back panel to remove it from the device.
  5. HP Pavilion dm4-1265dx Clock Battery Replacement, Clock Battery: Schritt 5, Bild 1 von 3 HP Pavilion dm4-1265dx Clock Battery Replacement, Clock Battery: Schritt 5, Bild 2 von 3 HP Pavilion dm4-1265dx Clock Battery Replacement, Clock Battery: Schritt 5, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • The clock battery is a metallic disk near the battery port. The words "Lithium 3V" are on the face.
    • Disconnect the battery from the metallic fasteners using the tweezers.
    • Slightly bend the fasteners away from the battery.
    • Pick up the battery with the tweezers and dislodge from the fasteners.
  6. HP Pavilion dm4-1265dx Clock Battery Replacement: Schritt 6, Bild 1 von 1
    • Fully remove battery from the laptop.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Casper College, Team 1-1, Lareau Spring 2022 Mitglied von Casper College, Team 1-1, Lareau Spring 2022
CASC-LAREAU-S22S1G1
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 22
Insgesamt: 376
