Zum Hauptinhalt wechseln
HP Pavilion dm4-1265dx Hard Drive Replacement
Was du brauchst
  1. HP Pavilion dm4-1265dx Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the laptop over so the bottom is facing up.
  2. HP Pavilion dm4-1265dx Hard Drive Replacement: Schritt 2, Bild 1 von 3 HP Pavilion dm4-1265dx Hard Drive Replacement: Schritt 2, Bild 2 von 3 HP Pavilion dm4-1265dx Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • Push the sliding lock to release the battery.
    • Remove the battery by lifting it away from the device.
  3. HP Pavilion dm4-1265dx Hard Drive Replacement, Back Panel: Schritt 3, Bild 1 von 2 HP Pavilion dm4-1265dx Hard Drive Replacement, Back Panel: Schritt 3, Bild 2 von 2
    • Orient the device so that the empty battery port is closest to you.
    • Loosen the two captive screws holding the back panel in place using a Phillips #0 screwdriver.
  4. HP Pavilion dm4-1265dx Hard Drive Replacement: Schritt 4, Bild 1 von 3 HP Pavilion dm4-1265dx Hard Drive Replacement: Schritt 4, Bild 2 von 3 HP Pavilion dm4-1265dx Hard Drive Replacement: Schritt 4, Bild 3 von 3
    • Pull back and lift the back panel to remove it from the device.
  5. HP Pavilion dm4-1265dx Hard Drive Replacement, Hard Drive: Schritt 5, Bild 1 von 3 HP Pavilion dm4-1265dx Hard Drive Replacement, Hard Drive: Schritt 5, Bild 2 von 3 HP Pavilion dm4-1265dx Hard Drive Replacement, Hard Drive: Schritt 5, Bild 3 von 3
    • Loosen the single captive screw holding the hard drive cover in place using a Phillips #0 screwdriver.
    • Lift the hard drive cover away and up to remove.
  6. HP Pavilion dm4-1265dx Hard Drive Replacement: Schritt 6, Bild 1 von 3 HP Pavilion dm4-1265dx Hard Drive Replacement: Schritt 6, Bild 2 von 3 HP Pavilion dm4-1265dx Hard Drive Replacement: Schritt 6, Bild 3 von 3
    • Lift the hard drive out of the device from the connector side.
    • Grasp the connector and pull it out of the hard drive.
    • Remove the hard drive from the laptop.
Abschluss
Matthew Walter
109 Reputation
1 Anleitung geschrieben
Casper College, Team 1-1, Lareau Spring 2022 Mitglied von Casper College, Team 1-1, Lareau Spring 2022
CASC-LAREAU-S22S1G1
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 14
Insgesamt: 364
