Zum Hauptinhalt wechseln
HP Pavilion dm4-1265dx Wi-Fi Card Replacement
Was du brauchst
  1. HP Pavilion dm4-1265dx Wi-Fi Card Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the laptop over so the bottom is facing up.
  2. HP Pavilion dm4-1265dx Wi-Fi Card Replacement: Schritt 2, Bild 1 von 3 HP Pavilion dm4-1265dx Wi-Fi Card Replacement: Schritt 2, Bild 2 von 3 HP Pavilion dm4-1265dx Wi-Fi Card Replacement: Schritt 2, Bild 3 von 3
    • Push the sliding lock to release the battery.
    • Remove the battery by lifting it away from the device.
  3. HP Pavilion dm4-1265dx Wi-Fi Card Replacement, Back Panel: Schritt 3, Bild 1 von 2 HP Pavilion dm4-1265dx Wi-Fi Card Replacement, Back Panel: Schritt 3, Bild 2 von 2
    • Orient the device so that the empty battery port is closest to you.
    • Loosen the two captive screws holding the back panel in place using a Phillips #0 screwdriver.
  4. HP Pavilion dm4-1265dx Wi-Fi Card Replacement: Schritt 4, Bild 1 von 3 HP Pavilion dm4-1265dx Wi-Fi Card Replacement: Schritt 4, Bild 2 von 3 HP Pavilion dm4-1265dx Wi-Fi Card Replacement: Schritt 4, Bild 3 von 3
    • Pull back and lift the back panel to remove it from the device.
  5. HP Pavilion dm4-1265dx Wi-Fi Card Replacement, Wi-Fi Card: Schritt 5, Bild 1 von 3 HP Pavilion dm4-1265dx Wi-Fi Card Replacement, Wi-Fi Card: Schritt 5, Bild 2 von 3 HP Pavilion dm4-1265dx Wi-Fi Card Replacement, Wi-Fi Card: Schritt 5, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Using ESD safe tweezers, gently disconnect the black and white wires connecting the Wi-Fi card to the device.
    • Move the wires out of the way to allow the Wi-Fi card to spring up without obstructions.
  6. HP Pavilion dm4-1265dx Wi-Fi Card Replacement: Schritt 6, Bild 1 von 2 HP Pavilion dm4-1265dx Wi-Fi Card Replacement: Schritt 6, Bild 2 von 2
    • Remove the two 3.0 mm screws from the Wi-Fi card using a Phillips #0 screwdriver.
  7. HP Pavilion dm4-1265dx Wi-Fi Card Replacement: Schritt 7, Bild 1 von 3 HP Pavilion dm4-1265dx Wi-Fi Card Replacement: Schritt 7, Bild 2 von 3 HP Pavilion dm4-1265dx Wi-Fi Card Replacement: Schritt 7, Bild 3 von 3
    • The Wi-Fi card will spring upwards.
    • Gently remove the Wi-Fi card by pulling it away from its socket.
Abschluss
Mason Hall
231 Reputation
2 Anleitungen geschrieben
Casper College, Team 1-1, Lareau Spring 2022 Mitglied von Casper College, Team 1-1, Lareau Spring 2022
CASC-LAREAU-S22S1G1
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 14
Insgesamt: 237
