Einleitung
This guide will take you through the process of replacing a keyboard for a HP Pavilion dv1000.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Shut down the computer.
Disconnect all external devices and cables from the computer.
Locate the gray sliding tab next to the black bar where the battery is located.
Slide the gray sliding tab to the left until you hear a distinct click.
The inside edge of the battery should pop up.
Grasp the inside edge of the battery.
Lift the inside edge of the battery up to detach the battery from the laptop.
Remove the highlighted screws.
After removing the screws, flip the laptop over.
Open the laptop.
Use the spudger to lift the keyboard.
Press the two white clips forward with your fingers and gently pull the ribbon from the clips.
Ein weiterer Nutzer hat diese Anleitung absolviert.
