Zum Hauptinhalt wechseln
HP Pavilion dv2000 Hard Drive Replacement
Was du brauchst
  1. HP Pavilion dv2000 Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 2 HP Pavilion dv2000 Hard Drive Replacement, Hard Drive: Schritt 1, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Phillips #00 Screwdriver
    $5.49
    Kaufen
    • Flip your computer over, so that the underside of your computer is facing upward.
    • Make sure your computer is powered down and unplugged from the charger before removing any components.
    • Locate the hard drive casing on the bottom-right corner of your flipped computer.
    • Remove the two 3.8mm screws with your Phillips #00 Screwdriver and carefully lift up and remove the hard drive casing.
    • Screws on hard drive casing will remain in casing after being unscrewed.
  2. HP Pavilion dv2000 Hard Drive Replacement: Schritt 2, Bild 1 von 3 HP Pavilion dv2000 Hard Drive Replacement: Schritt 2, Bild 2 von 3 HP Pavilion dv2000 Hard Drive Replacement: Schritt 2, Bild 3 von 3
    Phillips #000 Screwdriver
    $5.49
    Kaufen
    • After you lift off the hard drive casing, using your Phillips #000 Screwdriver, remove the two 3.6mm screws located on the right side of the hard drive.
    • Using your fingers, carefully lift the lower right corner of your hard drive until it is removed from its housing.
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
Erik Muniz
820 Reputation
3 Anleitungen geschrieben
CSU Fullerton, Team 2-3, Bruce Fall 2014 Mitglied von CSU Fullerton, Team 2-3, Bruce Fall 2014
CSUF-BRUCE-F14S2G3
3 Mitglieder
Ein Kommentar
You didnt mention this HDD has a different SATA connector , I cant find it in the market, instead of plug in , this one is for pressing down only
tml215 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 4,217
