Einleitung
This guide will help you replace the wireless card on you HP Pavilion dv2000.
Was du brauchst
Locate and unscrew the single 3.8mm screw holding the wireless card casing in place.
Lift up and remove the wireless card casing.
Use a pair of tweezers to remove the three antennas from their sockets.
Remove the two 3.8mm screws holding down the wireless card with your Phillips #00 Screwdriver.
Gently pull out your wireless card from its top side to remove it from its holding.
3 weitere Personen haben diese Anleitung absolviert.
