Zum Hauptinhalt wechseln
HP Pavilion dv2700 Camera Module Replacement
Was du brauchst
  1. HP Pavilion dv2700 Camera Module Replacement, Camera Module: Schritt 1, Bild 1 von 1
    • Disconnect device from power source and power down.
    • Disconnect any other external devices.
  2. HP Pavilion dv2700 Camera Module Replacement: Schritt 2, Bild 1 von 3 HP Pavilion dv2700 Camera Module Replacement: Schritt 2, Bild 2 von 3 HP Pavilion dv2700 Camera Module Replacement: Schritt 2, Bild 3 von 3
    • Flip the laptop over so that the bottom is facing upwards.
    • Use your index finger to push the battery latch.
    • Pivot the battery upward and lift it out of the socket to remove it.
  3. HP Pavilion dv2700 Camera Module Replacement: Schritt 3, Bild 1 von 1
    • Flip the laptop right side up.
    • Open it as wide as the hinge allows it to.
  4. HP Pavilion dv2700 Camera Module Replacement: Schritt 4, Bild 1 von 3 HP Pavilion dv2700 Camera Module Replacement: Schritt 4, Bild 2 von 3 HP Pavilion dv2700 Camera Module Replacement: Schritt 4, Bild 3 von 3
    • Use an opening tool to remove the four rubber screw covers located across the top of the bezel.
    • Remove the Phillips PM2.5×5.0 screws.
    • Remove the two rubber screw covers located at the bottom left and right of the bezel.
  5. HP Pavilion dv2700 Camera Module Replacement: Schritt 5, Bild 1 von 3 HP Pavilion dv2700 Camera Module Replacement: Schritt 5, Bild 2 von 3 HP Pavilion dv2700 Camera Module Replacement: Schritt 5, Bild 3 von 3
    • Flex the inside edges of the left and right sides and the top edge of the display bezel.
    • Lift the bezel with your finger until it disengages from the display enclosure.
  6. HP Pavilion dv2700 Camera Module Replacement: Schritt 6, Bild 1 von 3 HP Pavilion dv2700 Camera Module Replacement: Schritt 6, Bild 2 von 3 HP Pavilion dv2700 Camera Module Replacement: Schritt 6, Bild 3 von 3
    • Remove the two Phillips PM2.5×4.0 screws that secure camera module.
    • Release the camera module assembly unit by simply pulling it out of the laptop.
  7. HP Pavilion dv2700 Camera Module Replacement: Schritt 7, Bild 1 von 3 HP Pavilion dv2700 Camera Module Replacement: Schritt 7, Bild 2 von 3 HP Pavilion dv2700 Camera Module Replacement: Schritt 7, Bild 3 von 3
    • Disconnect the camera module cable from the camera module itself by pulling it out.
    • Be careful not to break the camera module cable.
    • Turn the module upside down and remove the screws for the camera bracket.
    • Remove the camera module from the bracket.
Abschluss
Kayaen Jardine
145 Reputation
1 Anleitung geschrieben
York University, Team S1-G35, Allen Summer 2020 Mitglied von York University, Team S1-G35, Allen Summer 2020
YORK-ALLEN-SU20S1G35
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 16
Insgesamt: 462
