Einleitung
Be sure to turn off the computer and remove the battery in order to avoid any electrical hazards and further damages to the hard drive. An improper shutdown or the hard drive receiving power while being removed may lead to file corruption.
Was du brauchst
To remove the battery, pull the tab to the left and lift the battery from the computer.
Using a #0 Phillips Head screwdriver, unscrew the hard drive cover.
To remove the cover, lift up and to the left.
Using a #0 Phillips Head screwdriver, remove the screws holding the hard drive in place.
2 weitere Personen haben diese Anleitung absolviert.
