Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
This guide will accomplish replacing the WiFi receiver in incidents of failure.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Begin by locating the smallest panel with one screw attaching it to the laptop computer.
    • Begin by locating the smallest panel with one screw attaching it to the laptop computer.
  2. Remove the one screw holding the panel down, and the WiFi receiver will be revealed.
    • Remove the one screw holding the panel down, and the WiFi receiver will be revealed.
  3. Manta Precision Bit Set
    112 Bits für jede Reparatur.
    Upgrade Your Toolbox
  4. Remove the two screws that hold down the receiver.
    • Remove the two screws that hold down the receiver.
    • Gently slide the chip out of the socket.
  5. Remove the two wires labelled AUX and MAIN from the chip. Remember where these were attached previously as it is important for proper functionality after the replacement.
    • Remove the two wires labelled AUX and MAIN from the chip.
    • Remember where these were attached previously as it is important for proper functionality after the replacement.
Abschluss
Adam Braga
230 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 2-7, Isaacson Fall 2016 Mitglied von UMass Dartmouth, Team 2-7, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G7
3 Mitglieder
4 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 34
