Einleitung
The access only requires unplugging the power cable, the battery and removing a single compartment cover.
The type of memory is a DDR2 with SO-DIMM form factor, it has 2 slots, and it comes with 2GB each one from the factory, making a total of 4GB of memory.
According to the manufacturer, it admits up to 8GB of memory, however, 4GB DDR2 type DIMMs are very scarce and expensive; therefore I do not recommend them.
Although the factory modules have a frequency of 667mhz, the 800mhz modules should work, as the system must be able to lower their frequency to 667mhz.
Was du brauchst
Verify the laptop model. Remove the power cable.
The battery only requires to move a latch to the left. With this, it comes out by itself.
Use a #0 phillips screwdriver to remove the RAM container cover.
Remove the hooks that hold the memories.
You can place new memories type DDR2, size SO-DIMM.
100%
Penny hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
