Einleitung
Replacing the DVD drive involves removing the hard drive, but you do not need to open up the whole computer.
Was du brauchst
Lift the cover up by the tab near the screws.
The cover can be removed from the laptop.
Grab the hard drive from the sides and slide it away from the connectors.
Lift and remove the hard drive from the laptop.
Locate the one 2x5 mm screw in the hard drive bay.
Unscrew the screw with a #00 Phillips screwdriver.
Locate the hole next to the DVD drive release button.
Insert a paperclip into the hole to release the DVD drive.
4 weitere Personen haben diese Anleitung absolviert.
