Zum Hauptinhalt wechseln
HP Pavilion dv4000 CD/DVD drive Replacement
Was du brauchst
  1. HP Pavilion dv4000 CD/DVD drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the laptop upside down with the battery compartment facing you.
  2. HP Pavilion dv4000 CD/DVD drive Replacement: Schritt 2, Bild 1 von 1
    • Slide the battery release latch to the right and hold in place.
  3. HP Pavilion dv4000 CD/DVD drive Replacement: Schritt 3, Bild 1 von 1
    • Lift the front edge of the battery up and remove it from the compartment.
  4. HP Pavilion dv4000 CD/DVD drive Replacement, Hard Drive: Schritt 4, Bild 1 von 1
    • Orient the laptop with the hard drive panel towards you.
  5. HP Pavilion dv4000 CD/DVD drive Replacement: Schritt 5, Bild 1 von 1
    • Unscrew the two 2x5mm screws with a #00 Phillips screwdriver.
  6. HP Pavilion dv4000 CD/DVD drive Replacement: Schritt 6, Bild 1 von 2 HP Pavilion dv4000 CD/DVD drive Replacement: Schritt 6, Bild 2 von 2
    • Lift the cover up by the tab near the screws.
    • The cover can be removed from the laptop.
  7. HP Pavilion dv4000 CD/DVD drive Replacement: Schritt 7, Bild 1 von 1
    • Grab the hard drive from the sides and slide it away from the connectors.
    • The hard drive should disconnect with light force. If it doesn't easily slide out, ensure there are no cables or obstacles preventing it from moving.
    • Lift and remove the hard drive from the laptop.
    • We did not have a hard drive in our laptop to demonstrate how to remove it.
  8. HP Pavilion dv4000 CD/DVD drive Replacement, CD/DVD Drive: Schritt 8, Bild 1 von 2 HP Pavilion dv4000 CD/DVD drive Replacement, CD/DVD Drive: Schritt 8, Bild 2 von 2
    • Locate the one 2x5 mm screw in the hard drive bay.
    • Unscrew the screw with a #00 Phillips screwdriver.
  9. HP Pavilion dv4000 CD/DVD drive Replacement: Schritt 9, Bild 1 von 3 HP Pavilion dv4000 CD/DVD drive Replacement: Schritt 9, Bild 2 von 3 HP Pavilion dv4000 CD/DVD drive Replacement: Schritt 9, Bild 3 von 3
    • Locate the hole next to the DVD drive release button.
    • Insert a paperclip into the hole to release the DVD drive.
  10. HP Pavilion dv4000 CD/DVD drive Replacement: Schritt 10, Bild 1 von 2 HP Pavilion dv4000 CD/DVD drive Replacement: Schritt 10, Bild 2 von 2
    • Carefully grasp the DVD drive and slide it out.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Nick LaMarche
373 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 4-2, Catania Fall 2016 Mitglied von UMass Dartmouth, Team 4-2, Catania Fall 2016
UMASSD-CATANIA-F16S4G2
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 21
Insgesamt: 1,324
