Einleitung
The hard drive is a crucial component of your laptop (storing files and the operating system). It is also one of the most likely causes of issues with your machine. The hard drive can become corrupted with age or physical damage. Replacing your hard drive with a bigger one for more storage is a common practice as well.
Was du brauchst
Lift the cover up by the tab near the screws.
The cover can be removed from the laptop.
Grab the hard drive from the sides and slide it away from the connectors.
Lift and remove the hard drive from the laptop.
To replace the hard drive, follow these instructions in reverse.
Eine weitere Person hat diese Anleitung absolviert.
