Zum Hauptinhalt wechseln
HP Pavilion dv4000 Hard Drive Replacement
Was du brauchst
  1. HP Pavilion dv4000 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the laptop upside down with the battery compartment facing you.
  2. HP Pavilion dv4000 Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Slide the battery release latch to the right and hold in place.
  3. HP Pavilion dv4000 Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Lift the front edge of the battery up and remove it from the compartment.
  4. HP Pavilion dv4000 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 1
    • Orient the laptop with the hard drive panel towards you.
  5. HP Pavilion dv4000 Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Unscrew the two 2x5mm screws with a #00 Phillips screwdriver.
  6. HP Pavilion dv4000 Hard Drive Replacement: Schritt 6, Bild 1 von 2 HP Pavilion dv4000 Hard Drive Replacement: Schritt 6, Bild 2 von 2
    • Lift the cover up by the tab near the screws.
    • The cover can be removed from the laptop.
  7. HP Pavilion dv4000 Hard Drive Replacement: Schritt 7, Bild 1 von 1
    • Grab the hard drive from the sides and slide it away from the connectors.
    • The hard drive should disconnect with light force. If it doesn't easily slide out, ensure there are no cables or obstacles preventing it from moving.
    • Lift and remove the hard drive from the laptop.
    • We did not have a hard drive in our laptop to demonstrate how to remove it.
Abschluss
To replace the hard drive, follow these instructions in reverse.
2 weitere Personen haben diese Anleitung absolviert.
UMass Dartmouth, Team 4-2, Catania Fall 2016 Mitglied von UMass Dartmouth, Team 4-2, Catania Fall 2016
UMASSD-CATANIA-F16S4G2
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 25
Insgesamt: 2,117
