Einleitung
If your keyboard is not working, keys are sticking, or keys are missing, it may be time to replace your keyboard.
Was du brauchst
Have your device open in front of you for easy access to the keyboard.
Using a metal spudger, pry up on the plastic piece above the keyboard containing the power button.
Place the plastic piece on the keyboard so the ribbon strip is easily accessible.
Carefully disconnect the ribbon strip from the keyboard by pressing on the tabs at the edges.
Remove plastic piece and set aside.
Pry at the edges of the plastic clip holding the ribbon cable to the motherboard.
Eine weitere Person hat diese Anleitung absolviert.
