Einleitung
The hard drive is the memory storage device located on the bottom of the laptop, directly below the track pad.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Lay the computer face-down on a flat surface. Orient the computer to match the image.
Locate the battery release switch, as indicated in the image by the red rectangle. Slide the switch from right to left, and remove the battery.
Locate the hard drive cover. Note that in this image, the RAM cover is still in place.
Slide the hard drive to the right until the edge of the hard drive is flush with the computer frame.
Lift the hard drive out of the hard drive bay, left side first.
To reinstall the hard drive and reassemble your device, follow these instructions in reverse order.
Ein weiterer Nutzer hat diese Anleitung absolviert.
