Einleitung
This guide will show how to replace the hard drive in the HP Pavilion dv6-2155dx.
Was du brauchst
Loosen the screws using Phillips #01 screwdriver with the extension attached.
After removing the two screws securing the Hard Drive to the bottom case, remove the panel to reveal the hard drive.
Locate the tab of the black Mylar film on the right hand side of the hard drive.
Gently grip it with your thumb and index finger.
Pull the Hard Drive to the right to loosen the it from the frame.
The left side of the hard drive will pop up and should slide out freely until you see the black connector on it's right side, connecting it to the computer.
Turn the Hard Drive over and grasp the Hard Drive with one hand as you grip the connector with the other hand to remove the connector from the hard drive.
1 Kommentar zur Anleitung
Can I transfer the information on the hard drive to another computer? How? My laptop won’t turn on and I’ve tried everything.
