Zum Hauptinhalt wechseln
Einleitung
The random access memory (RAM) stores temporary data for programs to use while they are running. Some programs use a lot of memory so it may be useful to replace RAM with ones with more memory on them.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Locate the battery on the bottom side of the laptop. Slide the release switch and the battery will pop out. Remove the battery
    • Locate the battery on the bottom side of the laptop.
    • Slide the release switch and the battery will pop out.
    • Remove the battery
  2. Using the Phillips #1, loosen the three 7mm captive screws that secure the memory module cover to the computer.
    • Using the Phillips #1, loosen the three 7mm captive screws that secure the memory module cover to the computer.
  3. Remove cover and expose the memory module by lifting the cover up like its on a hinge. Remove cover and expose the memory module by lifting the cover up like its on a hinge. Remove cover and expose the memory module by lifting the cover up like its on a hinge.
    • Remove cover and expose the memory module by lifting the cover up like its on a hinge.
  4. Locate the release tabs on both sides of the RAM. Use non-conductive pointing tool or fingers to prevent static build up and damaging components. Pull the metal tabs away from the memory to release it.
    • Locate the release tabs on both sides of the RAM.
    • Use non-conductive pointing tool or fingers to prevent static build up and damaging components.
    • Pull the metal tabs away from the memory to release it.
    • Pull RAM away from clips to remove from device
    • Repeat for second RAM if necessary
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Chad
988 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 10-34, Maness Winter 2014 Mitglied von Cal Poly, Team 10-34, Maness Winter 2014
CPSU-MANESS-W14S10G34
4 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 4
Letzten 30 Tage: 8
Insgesamt: 1,303
