Zum Hauptinhalt wechseln
HP Pavilion dv6-2158nr Speaker Assembly Replacement
Was du brauchst
    1. HP Pavilion dv6-2158nr Speaker Assembly Replacement, Battery: Schritt 1, Bild 1 von 3 HP Pavilion dv6-2158nr Speaker Assembly Replacement, Battery: Schritt 1, Bild 2 von 3 HP Pavilion dv6-2158nr Speaker Assembly Replacement, Battery: Schritt 1, Bild 3 von 3
      • Locate the battery on the bottom side of the laptop.
      • Slide the release switch and the battery will pop out.
      • Remove the battery
      Frag FixBot
      Kommentar hinzufügen
    1. HP Pavilion dv6-2158nr Speaker Assembly Replacement, Keyboard: Schritt 2, Bild 1 von 3 HP Pavilion dv6-2158nr Speaker Assembly Replacement, Keyboard: Schritt 2, Bild 2 von 3 HP Pavilion dv6-2158nr Speaker Assembly Replacement, Keyboard: Schritt 2, Bild 3 von 3
      • Using a Philips #1 Loosen the three 7mm captive screws that secure the memory module compartment cover to the computer.
      • Lift the rear edge of the cover, swing it up and to the front, and remove the cover.
      Frag FixBot
    2. HP Pavilion dv6-2158nr Speaker Assembly Replacement: Schritt 3, Bild 1 von 2 HP Pavilion dv6-2158nr Speaker Assembly Replacement: Schritt 3, Bild 2 von 2
      • Loosen the two 6mm captive screws that secure the hard drive port bezel cover to the computer, using a Philips #1.
      • Lift the right side of the hard drive port bezel cover, swing it up and to the left, and remove the cover.
      Frag FixBot
    3. HP Pavilion dv6-2158nr Speaker Assembly Replacement: Schritt 4, Bild 1 von 3 HP Pavilion dv6-2158nr Speaker Assembly Replacement: Schritt 4, Bild 2 von 3 HP Pavilion dv6-2158nr Speaker Assembly Replacement: Schritt 4, Bild 3 von 3
      • Use the Mylar tab to lift the hard drive up, and then slide it to the left to release it from the hard drive bay.
      Frag FixBot
    4. HP Pavilion dv6-2158nr Speaker Assembly Replacement: Schritt 5, Bild 1 von 2 HP Pavilion dv6-2158nr Speaker Assembly Replacement: Schritt 5, Bild 2 von 2
      • Disconnect the hard drive cable from the system board.
      • Remove the hard drive from the hard drive bay and set it aside.
      Frag FixBot
    5. HP Pavilion dv6-2158nr Speaker Assembly Replacement: Schritt 6, Bild 1 von 2 HP Pavilion dv6-2158nr Speaker Assembly Replacement: Schritt 6, Bild 2 von 2
      • With laptop upside down locate the three sets of screws that fasten the keyboard and switch cover.
      • Two Phillips 7mm screws that secure the switch cover to the computer.
      • Four Phillips 4.0mm screws that secure the switch cover to the computer. (these are inside the battery bay)
      • Four Philips 7mm screws that secure the keyboard to the computer.
      • Remove all ten screws.
      Frag FixBot
    6. HP Pavilion dv6-2158nr Speaker Assembly Replacement: Schritt 7, Bild 1 von 2 HP Pavilion dv6-2158nr Speaker Assembly Replacement: Schritt 7, Bild 2 von 2
      • Turn the computer over, and locate the Switch Cover.
      • Using the Safe Pry Tool, un-clip the Switch Cover until it detaches from the computer.
      • The clips will need careful prying to unhook.
      Frag FixBot
    7. HP Pavilion dv6-2158nr Speaker Assembly Replacement: Schritt 8, Bild 1 von 3 HP Pavilion dv6-2158nr Speaker Assembly Replacement: Schritt 8, Bild 2 von 3 HP Pavilion dv6-2158nr Speaker Assembly Replacement: Schritt 8, Bild 3 von 3
      • Slide the Switch Cover onto the LCD Monitor, exposing the Speaker Assembly.
      • There are two ribbon cables still attached to the speaker assembly
      • Detach the two ribbon cables from the speaker assembly.
      Frag FixBot
    8. HP Pavilion dv6-2158nr Speaker Assembly Replacement: Schritt 9, Bild 1 von 3 HP Pavilion dv6-2158nr Speaker Assembly Replacement: Schritt 9, Bild 2 von 3 HP Pavilion dv6-2158nr Speaker Assembly Replacement: Schritt 9, Bild 3 von 3
      • Remove the three silver Phillips 3.5mm screws that secure the keyboard to the computer.
      • Lift the rear edge of the keyboard and slide the keyboard back until the keyboard connector on the system board is accessible.
      Frag FixBot
    9. HP Pavilion dv6-2158nr Speaker Assembly Replacement: Schritt 10, Bild 1 von 3 HP Pavilion dv6-2158nr Speaker Assembly Replacement: Schritt 10, Bild 2 von 3 HP Pavilion dv6-2158nr Speaker Assembly Replacement: Schritt 10, Bild 3 von 3
      • Unhinge the zero insertion force (ZIF) connector to release the ribbon cable then pull gently on the cable to release.
      • You need to unhinge the blue plastic to release the ribbon cable from the main board.
      • The keyboard can now be lifted off and set aside.
      Frag FixBot
    1. HP Pavilion dv6-2158nr Speaker Assembly Replacement, Speaker Assembly: Schritt 11, Bild 1 von 2 HP Pavilion dv6-2158nr Speaker Assembly Replacement, Speaker Assembly: Schritt 11, Bild 2 von 2
      • Position the computer with the keyboard facing up its front edge toward you.
      • Disconnect the speaker cable from the system board.
      Frag FixBot
    2. HP Pavilion dv6-2158nr Speaker Assembly Replacement: Schritt 12, Bild 1 von 2 HP Pavilion dv6-2158nr Speaker Assembly Replacement: Schritt 12, Bild 2 von 2
      • Using the Phillips #1 screwdriver, remove the four Phillips 4mm screws that secure the speaker assembly.
      • You will also need the Phillips #1 screwdriver to remove the Phillips 7mm screw that secures the center of the speaker assembly.
      • Remove the speaker assembly from the computer.
      Frag FixBot
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Chad
1.123 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 10-34, Maness Winter 2014 Mitglied von Cal Poly, Team 10-34, Maness Winter 2014
CPSU-MANESS-W14S10G34
4 Mitglieder
72 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 33
Insgesamt: 3,464
