Zum Hauptinhalt wechseln
HP Pavilion dv6-6117dx Optical Drive Replacement
Was du brauchst
  1. HP Pavilion dv6-6117dx Optical Drive Replacement, Optical Drive: Schritt 1, Bild 1 von 2 HP Pavilion dv6-6117dx Optical Drive Replacement, Optical Drive: Schritt 1, Bild 2 von 2
    • Begin removing the bottom cover by sliding the battery removal slider to the right to pop off the top of the cover.
  2. HP Pavilion dv6-6117dx Optical Drive Replacement: Schritt 2, Bild 1 von 2 HP Pavilion dv6-6117dx Optical Drive Replacement: Schritt 2, Bild 2 von 2
    • Slide a black spudger under the top of the cover to loosen the clips underneath.
  3. HP Pavilion dv6-6117dx Optical Drive Replacement: Schritt 3, Bild 1 von 3 HP Pavilion dv6-6117dx Optical Drive Replacement: Schritt 3, Bild 2 von 3 HP Pavilion dv6-6117dx Optical Drive Replacement: Schritt 3, Bild 3 von 3
    • Slide the spudger down the left side of the cover to loosen the clips.
    • After the left side is loose, the rest of the cover should pop off, and you can remove it with your hands.
    • When reassembling, insert the bottom of the cover first, and then firmly press along the edges from bottom to top to secure it in place.
  4. HP Pavilion dv6-6117dx Optical Drive Replacement: Schritt 4, Bild 1 von 3 HP Pavilion dv6-6117dx Optical Drive Replacement: Schritt 4, Bild 2 von 3 HP Pavilion dv6-6117dx Optical Drive Replacement: Schritt 4, Bild 3 von 3
    • Using a Phillips #0 screw driver, remove the single 4mm screw holding the optical drive in place
  5. HP Pavilion dv6-6117dx Optical Drive Replacement: Schritt 5, Bild 1 von 3 HP Pavilion dv6-6117dx Optical Drive Replacement: Schritt 5, Bild 2 von 3 HP Pavilion dv6-6117dx Optical Drive Replacement: Schritt 5, Bild 3 von 3
    • Using a plastic spudger, push the optical drive out toward the left of the device
Abschluss
Joshua Holme
765 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team S6-G3, Bernier Spring 2018 Mitglied von UMass Dartmouth, Team S6-G3, Bernier Spring 2018
UMASSD-BERNIER-S18S6G3
3 Mitglieder
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 7
Letzte 30 Tage: 9
Insgesamt: 331
