Einleitung
Are you unable to connect to WiFi? Your WiFi adapter may be broken. This guide will walk you through replacing it with a new, working WiFi adapter, with only a spudger and a Phillips #0 screw driver. Once you have a clean work space and the tools required, follow the steps below.
Was du brauchst
Begin removing the bottom cover by sliding the battery removal slider to the right to pop off the top of the cover.
Slide a black spudger under the top of the cover to loosen the clips underneath.
Slide the spudger down the left side of the cover to loosen the clips.
After the left side is loose, the rest of the cover should pop off, and you can remove it with your hands.
Using a spudger, remove the white and black antenna wires from the WiFi Adapter
Using a Phillips #0 screw driver, remove the two 4mm screws holding the WiFi adapter in place
After the screws are removed the WiFi Adapter will raise to a 45º angle.
2 weitere Personen haben diese Anleitung absolviert.
