Was du brauchst
REMOVING THE BATTERY: Flip the laptop over with the battery side facing up.
Slide the battery release latch to release the battery.
Pivot the front edge of the battery up and back.
Remove the battery.
REPLACING THE BATTERY: Align the tabs on the rear edge of the battery with the notches on the rear edge of the battery bay.
Pivot the front edge of the battery down into the battery bay until it is fully seated. (The battery release latch will automatically lock into place.)
Battery part number: 593554-001
Slide the service cover release latch to release the service cover.
Lift the rear edge of the service cover up and forward until it rests at an angle, being careful not to break the small plastic tabs that hold the cover in place. (A plastic spudger can be used to release the tabs)
Remove the service cover.
Spread the retaining tabs on each side of the memory module slot to release the memory module. (The memory module tilts up.)
Remove the memory module by pulling it away from the slot at an angle.
Some notes to consider:
- Make sure to use compatible memory modules when replacing the old memory modules.
- Make sure to line up the notches on the memory slots before inserting them. Do not force it in, as the memory module can only fit one way on the slot.
Eine weitere Person hat diese Anleitung absolviert.
