Einleitung
Replace the LCD in your HP Pavilion dv6000.
Werkzeuge
Ersatzteile
Remove rubber screw covers from the LCD screen. The top covers pop off with a fingernail but the two on the bottom may require a screwdriver or flat tool.
Remove the six 7.15mm screws underneath the stoppers. There are four on top and two on bottom.
Press the tabs on the sides of the screen in and pop the plastic off. Careful, the plastic is very flimsy and may break.
Remove the two screws (5.8mm) on either side of the LCD near the hinge. Remove the screws on the outermost side first.
Hold on to the LCD screen to prevent it from falling over and remove the two 3.58mm screws on the sides at the bottom.
15 weitere Nutzer haben diese Anleitung absolviert.
Ein Kommentar
after replacing my cracked screen the back light does not show again
