Zum Hauptinhalt wechseln
HP Pavilion dv6000 RAM Replacement
Was du brauchst
  1. HP Pavilion dv6000 RAM Replacement, RAM: Schritt 1, Bild 1 von 3 HP Pavilion dv6000 RAM Replacement, RAM: Schritt 1, Bild 2 von 3 HP Pavilion dv6000 RAM Replacement, RAM: Schritt 1, Bild 3 von 3
    • Remove the two screws from the memory shield and lift up. The screws will remain into the shield
  2. HP Pavilion dv6000 RAM Replacement: Schritt 2, Bild 1 von 3 HP Pavilion dv6000 RAM Replacement: Schritt 2, Bild 2 von 3 HP Pavilion dv6000 RAM Replacement: Schritt 2, Bild 3 von 3
    • Using a plastic spudger depress the pins holding the RAM in. If you have an anti-static work surface or wristband, you may suppress the pins with your thumbs.
    • Static charge built up on surfaces contacting the RAM or other computer components can damage and destroy the components. Always discharge yourself before handling these components!
    • Pull the RAM straight out.
  3. HP Pavilion dv6000 RAM Replacement: Schritt 3, Bild 1 von 1
    • Under the first RAM stick is another. Remove it in the same way by pushing the silver tabs away and down from the RAM stick and remove the RAM once it pops up.
  4. HP Pavilion dv6000 RAM Replacement: Schritt 4, Bild 1 von 1
    • You have removed your RAM!
    • If you want to expand your RAM you will have to use DDR2 PC2-5300 SODIMM laptop memory modules, they are clocked at 667MHz
    • To reinstall your RAM, follow this guide in the reverse order
Abschluss
19 weitere Personen haben diese Anleitung absolviert.
Ben Hirsch
3.877 Reputation
10 Anleitungen geschrieben
Cal Poly, Team 21-33, Regan Fall 2010 Mitglied von Cal Poly, Team 21-33, Regan Fall 2010
CPSU-REGAN-F10S21G33
4 Mitglieder
12 Anleitungen geschrieben
3 Kommentare zur Anleitung
if you have bios version f.25 or newer you can have up to 4gb of ram
Bryce Stidman - Antwort Teilen
2+2 or 4+4 ? which one?
Jes White - Teilen
That is pretty helpful. I think I am going to update my bios, not to mention the article forgot to mention to have a DDR2 ram. Just make sure to look for a DDR2 PC2- 5300 version with 667 MHz.
Tommy E. - Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 59
Insgesamt: 35,495
