Zum Hauptinhalt wechseln
HP Pavilion dv6500 Keyboard Replacement
Was du brauchst
  1. HP Pavilion dv6500 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip computer face down.
  2. HP Pavilion dv6500 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery by sliding the button to the side.
    • Be careful if the battery is leaking or appears punctured in anyway. Battery acid is harmful and may cause burns.
  3. HP Pavilion dv6500 Keyboard Replacement, Back Panel: Schritt 3, Bild 1 von 1
    • Remove fifteen 7.0mm PH0 screws.
    • Remove five silver 4.0mm PH 0 screws inside the cavity for the battery.
  4. HP Pavilion dv6500 Keyboard Replacement, Keyboard: Schritt 4, Bild 1 von 2 HP Pavilion dv6500 Keyboard Replacement, Keyboard: Schritt 4, Bild 2 von 2
    • Gently lift the plastic panel on the top of the laptop at the divide until the two ribbon cables and cable leads are visible with their ports on left side on laptop.
  5. HP Pavilion dv6500 Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Gently pull on the 2 ribbon cables until they detach from the computer.
    • Unplug cables connecting the top keyboard assembly and computer body.
    • Be careful not to rip the speaker cables.
  6. HP Pavilion dv6500 Keyboard Replacement: Schritt 6, Bild 1 von 1
    • The top of the keyboard should be exposed enough to unclip and slide the keyboard out from the clips near the trackpad on the laptop.
    • Gently pull the flat black cable toward the monitor to remove the cable from the motherboard, freeing the keyboard.
    • Be careful not to pull too hard and damage the black cable.
  7. HP Pavilion dv6500 Keyboard Replacement: Schritt 7, Bild 1 von 1
    • Insert new keyboard by sliding it into place of original keyboard and clipping into place near top of trackpad.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
ollie
575 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 1-6, Catania Fall 2016 Mitglied von UMass Dartmouth, Team 1-6, Catania Fall 2016
UMASSD-CATANIA-F16S1G6
3 Mitglieder
7 Anleitungen geschrieben
Ein Kommentar
Je constate que régulièrement, il n’est pas mentionné de se décharger de son électricité statique. En dehors de tout équimement spécifique, il suffit, par exemple de toucher le bouton de purge d’un radiateur de chauffage central ou la fiche “terre” d’une prise 2 + T
Bernard RUETTE - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 12
Insgesamt: 1,603
