Zum Hauptinhalt wechseln
HP Pavilion dv7-1285dx Back Plate Replacement
Was du brauchst
  1. HP Pavilion dv7-1285dx Back Plate Replacement, Battery: Schritt 1, Bild 1 von 1
    • Ensure the device is powered down and unplugged.
    • Turn the device upside down with the battery compartment facing you.
    • Slide the black slider to the right and lift the battery out of its compartment.
  2. HP Pavilion dv7-1285dx Back Plate Replacement, Back Plate: Schritt 2, Bild 1 von 1
    • Locate and remove the six Phillips PM2.5×7.0 screws around the perimeter of the back plate.
    • These screws do not completely detach from the device when unscrewed.
  3. HP Pavilion dv7-1285dx Back Plate Replacement: Schritt 3, Bild 1 von 2 HP Pavilion dv7-1285dx Back Plate Replacement: Schritt 3, Bild 2 von 2
    • Use the plastic opening tool to lift up the back plate and set it aside.
Abschluss
Chris Apple
239 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 12-34, Maness Spring 2014 Mitglied von Cal Poly, Team 12-34, Maness Spring 2014
CPSU-MANESS-S14S12G34
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 13
Insgesamt: 1,524
