Einleitung
This guide will explain how to properly remove and replace the RAM of a HP Pavilion dv7-1285dx.
Was du brauchst
Ensure the device is powered down and unplugged.
Turn the device upside down with the battery compartment facing you.
Slide the black slider to the right and lift the battery out of its compartment.
Locate and remove the six Phillips PM2.5×7.0 screws around the perimeter of the back plate.
Locate the grey clips on the side of the RAM and pull the grey clips away from the RAM using the plastic opening tool.
Align the notch in the new RAM with the peg on the plug
Ensure the RAM is fully inserted into the plug at a 45 degree angle such that the notch of the RAM lines up with the peg on the plug
Push down gently on the RAM until the grey clips click.
Repeat steps 7 and 8 to replace the second piece of RAM.
Eine weitere Person hat diese Anleitung absolviert.
