Was du brauchst
Ensure the device is powered down and unplugged.
Turn the device upside down with the battery compartment facing you.
Slide the black slider to the right and lift the battery out of its compartment.
Locate and remove the six Phillips PM2.5×7.0 screws around the perimeter of the back plate.
Remove the two Phillips head screws located on the battery compartment side of the wifi card.
Fully insert the replacement wifi card at a 45 degree angle, ensuring that the notch on the card lines up with the peg on the plug.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
