Zum Hauptinhalt wechseln
HP Pavilion dv7-1448dx Battery Replacement
  1. HP Pavilion dv7-1448dx Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure the computer is unplugged and turned off.
    • Place the computer front side down with the battery compartment farthest away.
  2. HP Pavilion dv7-1448dx Battery Replacement: Schritt 2, Bild 1 von 2 HP Pavilion dv7-1448dx Battery Replacement: Schritt 2, Bild 2 von 2
    • Slide the switch under the battery compartment to the left until the compartment opens. This may require some force.
  3. HP Pavilion dv7-1448dx Battery Replacement: Schritt 3, Bild 1 von 2 HP Pavilion dv7-1448dx Battery Replacement: Schritt 3, Bild 2 von 2
    • Lightly pry the battery upward to remove.
    • When reinserting the battery, match the latches along the backside of the battery with the corresponding slots in the computer in order to press it into place.
Abschluss
To reinsert a new battery, follow these instructions in reverse order.
Baylor, Team 3-5, Whitney Spring 2017 Mitglied von Baylor, Team 3-5, Whitney Spring 2017
BU-WHITNEY-S17S3G5
2 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 226
