Zum Hauptinhalt wechseln
HP Pavilion dv7-1448dx Motherboard Replacement
Was du brauchst
  1. HP Pavilion dv7-1448dx Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure the computer is unplugged and turned off.
    • Place the computer front side down with the battery compartment farthest away.
  2. HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 2, Bild 1 von 2 HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Slide the switch under the battery compartment to the left until the compartment opens. This may require some force.
  3. HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 3, Bild 1 von 2 HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Lightly pry the battery upward to remove.
    • When reinserting the battery, match the latches along the backside of the battery with the corresponding slots in the computer in order to press it into place.
  4. HP Pavilion dv7-1448dx Motherboard Replacement, Motherboard: Schritt 4, Bild 1 von 3 HP Pavilion dv7-1448dx Motherboard Replacement, Motherboard: Schritt 4, Bild 2 von 3 HP Pavilion dv7-1448dx Motherboard Replacement, Motherboard: Schritt 4, Bild 3 von 3
    • Unscrew the six Phillips PM2.5×6.0 captive screws with a Phillips #00 screwdriver.
    • Pry the back casing up and away from the rest of the laptop with the plastic opening tool.
  5. HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 5, Bild 1 von 2 HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Disconnect the WLAN antenna cables.
  6. HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Remove the five Phillips PM2.5×7.0 screws with a Phillips #00 screwdriver.
    • Remove the 17 Phillips PM2.5×3.0 screws with a Phillips #00 screwdriver.
    • A magnet may be useful to help take out the screws.
  7. HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 7, Bild 1 von 3 HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 7, Bild 2 von 3 HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Remove the grey mounting bracket by unscrewing the two Phillips PM2.5×3.0 screws with a Phillips #00 screwdriver.
    • Slide the bracket to the left to remove.
  8. HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Remove the two Phillips PM2.5×4.0 broadhead screws with a Phillips #00 screwdriver.
  9. HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 9, Bild 1 von 3 HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 9, Bild 2 von 3 HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 9, Bild 3 von 3
    • Slide out and remove the black watch battery.
  10. HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 10, Bild 1 von 2 HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Turn the laptop over and open it so that the keyboard is exposed.
    • Lift off the speaker cover.
  11. HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 11, Bild 1 von 1
    • Remove the three Phillips PM2.5×3.0 screws, located on the speaker, with a Phillips #00 screwdriver.
  12. HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 12, Bild 1 von 2 HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 12, Bild 2 von 2
    • Unplug the white assembly cable.
  13. HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 13, Bild 1 von 1
    • Lift off the speaker.
  14. HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 14, Bild 1 von 2 HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 14, Bild 2 von 2
    • Remove the four Phillips PM2.0×4.0 screws with a Phillips #00 screwdriver.
    • Partially lift the keyboard to access the ribbon cable underneath.
  15. HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 15, Bild 1 von 1
    • Disconnect the black zero insertion force connector in order to completely remove the keyboard.
  16. HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 16, Bild 1 von 3 HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 16, Bild 2 von 3 HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 16, Bild 3 von 3
    • Unhook the black WLAN antenna cables from the clasps holding it in place.
    • Pull up to fully disconnect the ends of the WLAN antenna cables.
  17. HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 17, Bild 1 von 1
    • Disconnect the display panel cable.
  18. HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 18, Bild 1 von 3 HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 18, Bild 2 von 3 HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 18, Bild 3 von 3
    • Remove the seven Phillips PM2.0×4.0 screws from the base of the screen with a Phillips #00 screwdriver.
    • Lift up the screen to remove it from the rest of the laptop.
  19. HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 19, Bild 1 von 2 HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 19, Bild 2 von 2
    • Press in on the silver cover in order to eject the dust cover.
    • Pull the plastic dust cover to completely remove it from the laptop.
  20. HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 20, Bild 1 von 2 HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 20, Bild 2 von 2
    • Disconnect the white ribbon cable.
  21. HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 21, Bild 1 von 2 HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 21, Bild 2 von 2
    • Remove the six PM2.5X5.0 screws with a Phillips #00 screwdriver.
    • Next, remove the six PM2.5X2.0 screws with a Phillips #00 screwdriver.
  22. HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 22, Bild 1 von 3 HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 22, Bild 2 von 3 HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 22, Bild 3 von 3
    • Pry up on the metal casing to fully remove.
  23. HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 23, Bild 1 von 3 HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 23, Bild 2 von 3 HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 23, Bild 3 von 3
    • Disconnect the white cable near the bottom of the laptop.
  24. HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 24, Bild 1 von 3 HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 24, Bild 2 von 3 HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 24, Bild 3 von 3
    • Disconnect the white fan cable.
  25. HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 25, Bild 1 von 1
    • Lift the motherboard up and away from the rest of the laptop.
    • The motherboard is still not fully removed.
  26. HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 26, Bild 1 von 3 HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 26, Bild 2 von 3 HP Pavilion dv7-1448dx Motherboard Replacement: Schritt 26, Bild 3 von 3
    • Rotate the motherboard so that the backside is now facing upward. It should still be connected by a single cable.
    • Unplug the white power connector cable. The motherboard is now fully removed.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Baylor, Team 3-5, Whitney Spring 2017 Mitglied von Baylor, Team 3-5, Whitney Spring 2017
BU-WHITNEY-S17S3G5
2 Mitglieder
4 Anleitungen geschrieben
Ein Kommentar
This gets the east repairable laptop award.
trogfield - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 24
Insgesamt: 1,869
