Einleitung
This guide provides instructions for replacing the RAM. This may be helpful if your laptop is experiencing sluggish system performance.
Was du brauchst
Make sure the computer is unplugged and turned off.
Place the computer front side down with the battery compartment farthest away.
Slide the switch under the battery compartment to the left until the compartment opens. This may require some force.
Remove the six Phillips PM2.5X6.0 screws with a Phillips #00 screwdriver.
Pry the back casing up and away from the rest of the laptop with the plastic opening tool.
