Zum Hauptinhalt wechseln
HP Pavilion dv7-3065dx Disk Drive Replacement
Was du brauchst
  1. HP Pavilion dv7-3065dx Disk Drive Replacement, Disk Drive: Schritt 1, Bild 1 von 2 HP Pavilion dv7-3065dx Disk Drive Replacement, Disk Drive: Schritt 1, Bild 2 von 2
    • Remove the Battery as a safety precaution
    • There is a latch identified in the picture. By sliding this latch to the left, the battery is released from a lock position.
  2. HP Pavilion dv7-3065dx Disk Drive Replacement: Schritt 2, Bild 1 von 1
    • Use a Philips screwdriver to unscrew one screw holding the disk drive to the laptop.
    • In the photo there is a covering missing from another piece of the laptop but this will not impact the disk drive.
  3. HP Pavilion dv7-3065dx Disk Drive Replacement: Schritt 3, Bild 1 von 1
    • Slide (pull) the disk drive out from the laptop and place it off to the side.
    • The disk drive is the silver container as seen in the photo.
Abschluss
Bailey York
101 Reputation
1 Anleitung geschrieben
Ohio State, Team 1-5, Wilder Spring 2017 Mitglied von Ohio State, Team 1-5, Wilder Spring 2017
OSU-WILDER-S17S1G5
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 19
Insgesamt: 737
