Einleitung
Please note that this device did not have a physical hard drive to work with, so some photos are missing.
Was du brauchst
Place the laptop upside down on a flat surface so that the bottom is facing up.
Carefully pull out the battery while holding the latch to the open position with your finger.
Loosen the four screws that secure the hard drive panel with a Phillips head screwdriver.
Gently tug on the black tabs located on each end of the hard drive in order to loosen the hard drive from the motherboard.
Separate the hard drive from the cable by firmly gripping the hard drive and the black plug.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
