Einleitung
This guide will instruct you on how to replace the keyboard for your HP Pavilion dv7-3065dx.
Was du brauchst
Place the laptop upside down on a flat surface so that the bottom is facing up.
Carefully pull out the battery while holding the latch to the open position with your finger.
Loosen the four screws that secure the hard drive panel with a Phillips head screwdriver.
Gently tug on the black tabs located on each end of the hard drive in order to loosen the hard drive from the motherboard.
Separate the hard drive from the cable by firmly gripping the hard drive and the black plug.
Locate these seven screws that fasten the keyboard and switch cover to the computer.
Remove these screws
Flip over the computer to the upright position and locate the switch cover.
Carefully pry the switch cover up until it detaches from the computer.
Raise the switch cover to expose the speaker assembly.
Carefully detach the ribbon cables from the speaker assembly.
Locate and remove these four screws from the switch cover.
Locate and remove the screws that hold the keyboard to the computer.
Lift the keyboard up to expose the keyboard connector.
Disconnect the keyboard connector by unhinging the blue plastic clips and gently pulling the cord.
The keyboard can now be removed from the computer.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
